SOLD - Laney VC30 210 £200
Lovely two-channel valve combo with a distinct AC30 flavour to it. The clean channel has a beautifully chimey top end to it, and the drive channel has a great rock roar.
This is the 2x10 version with Eminence Legend speakers, meaning it’s nicely portable (unlike the 2x12 combo, which is heavy enough to disturb the Earth’s gravitational field) and cuts through nicely in a band mix. There’s a speaker out for connecting larger cabs, and a proper series FX loop. Other features are shared 3 band EQ with a bright switch, master tone and digital reverb.
Apart from the carry handle being a bit worn it’s in great nick. Valves were recently replaced (2x JJ EL84s, 2x JJ ECC83s and one Groove Tubes ECC83) and it comes with not one but TWO footswitches; the original one and a dinkier version which takes up less space on a pedalboard and has LEDs to indicate which channel is engaged and whether you’ve got the reverb on.
Collection from Leatherhead in Surrey; happy for anyone to come and have a play with it.
Spent a couple of hours playing it when I got it home.
Incredible amps for the money!
Look forward to cranking it soon
Many thanks Col...top fella!
