Hi all, I either need to add a pickup to my Taylor Big Baby guitar, or purchase a new (to me) electro acoustic. I think the pickup will be the more cost effective option as the Taylor is worth precisely nothing were I to sell it to find a new purchase.
I've tried a couple of Fishman soundhole pickups and for various reasons they just don't really work very well for me. I'd like to use it with IRs which I already have, and for that purpose I've found (via help from ttony) that I prefer the piezo sound.
Research has suggested that the K&K Pure Mini seems as good a deal as any, £92 from Thomann.
Is there a similar cost effective option I'm missing that might offer something better or different than that one?
EDIT: it's for accompanying my voice. Mostly play finger picking and strumming, don't typically use a pick, and I like silk & steel strings
Thanks
https://www.justgiving.com/page/pianomatt-1000lights
The only trouble now having watched the install video, is whether I trust the guitar tech near me to do it all as there looks like a lot to go wrong, with the drill and with glueing them in place
I don't really know anything about acoustic guitars (hence why I've got a cheap and nasty one I suppose) so assume I'm an idiot and you won't go far wrong
Prestige 220 £50
Many guitars have a re-sale value. Some you'll never want to sell.
Stockist of: Earvana & Graphtech nuts, Faber Tonepros & Gotoh hardware, Fatcat bridges. Highwood Saddles.
Expert guitar repairs and upgrades - fretwork our speciality! www.felineguitars.com. Facebook too!
Also I believe K&K use a smaller disc than the JourneyTek version but don't know for definite.
K&K Pure Mini transducer discs are 1/2" (12.7mm) diameter. The installation manual says that the transducer discs will lose about 30% of their output if stuck on with double-sided tape rather than superglue. While mentioning the positioning of the discs they say that on some bridges they have glued the two outside ones on first then stuck the middle one on with tape between them so that repositioning was possible if they needed to balance the sound. They say that the middle disc only contributes 15% of the overall output from the three discs anyway (if glued on) rather than 100/3 = 33.33%, so I suppose on a reduced size bridge plate it would be possible to instead use the 2x disc K&K Twin Spot version.
"Note: If installing on a guitar with narrow x-bracing under the saddle, such as a Martin Jr or Taylor GS Mini, one or more of the piezos may hang off of the edge slightly".
The JJB Prestige-330 transducer systems with 3 discs give the option to choose 15mm or 20mm diameter discs, whereas the Prestige GS-330 comes as standard with 15mm discs. I'm not sure of the disc size in the Prestige-220 system (i.e. only 2 discs), but on their site it suggests these as an alternative for smaller guitars like "parlor" ones.
Bandcamp
Spotify, Apple et al
My Gibson has that, because Gibson put a tooling hole right in the middle of the bridgeplate just where the centre pickup of the K&K would be - but since I run it through a modelling preamp it’s fine.
If you want to hear what it sounds like -
https://www.thefretboard.co.uk/discussion/comment/3915426/#Comment_3915426
