USA Badcat Cub IIIR Legacy Series Hand-wired 1x12 + footswitch + Hotcover
Pristine condition, Studio use only. Includes Heavy duty Hotcover.
Spec:
15-Watt. Single Channel. Class A. All- Valve Combo
Valves: 2× EL84 x EF86 1× 12AX7 × G734
Cathode biased
Bad Cat Celestion Speaker
Either 12AX7 (cleaner) or EF86 (dirtier) V1 valve, switchable via the front panel or the footswitch.
Boost function for adding gain and girth, again selectable via the front panel or the footswitch.
Tone stack switchable (via front panel only) between treble / bass knobs, or a rotary 5-way selector.
Cut control, which reduces high-end frequencies / presence.
FX loop.
Valve-driven spring reverb.
K-Master Volume
£1250
https://www.premierguitar.com/bad-cat-unveils-the-k-master-volume-circuit
Whatever the proper description is in circuitry terms it works very well and is up there with the best MVs I’ve use
