FS: Wudtone Trem, Torty Pickguard, Highwood saddles
Having a bit of a clear out if anyone is interested in some strat parts.
GSP Reverse headstock strat neck, 9.5 radius chunky C shape, great fret job. Is finished in monty's relic wax and has some shallow pyrography on the headstock that would easily sand off. This is a great neck but as you would expect from GSP but I cant get on with the radius. came to me on a partscaster earlier this year.
£150 £130 posted SOLD
The trem from the same partscaster. This is a narrow spaced trem, I think it is wudtone, definitely well made with a quality trem block.
There is evidence of the saddle spring holes on the bridge plate being enlarged but this doesn't affect function. Just noticed tonight that the string though holes in the bridge have also been redrilled to work with 56mm saddles even though it is a 54mm spaced bridge with 56mm mounting holes!
£45 posted
Set of highwood saddles, these are single dot 10.8mm wide saddles
£20 posted
Official Fender Torty Pickguard
£35 posted
