not worth the effort or expense as I live in North Wales
did read that these amp do show problems
regards Stan
Tbh, there isn’t a golden Bullet issue with the HT40 mk2 - genuinely they’re actually pretty reliable. If you get stuck, call the service team at Blackstar - whilst you’re not local to Northampton, there will be other options.
Good luck.
will try all your suggestions
much appreciated
Stan
something to look at. one valve looks a little dimmer, but could be my eyes.
Stan
) suggested a faulty power valve and sticking a spare one in each position in turn proved they were right. So definitely worth a try OP before you take it to a tech.
will source a valve, as I said all I get is a hum on either channel that gets louder with the volume controls...
Stan
will take that into consideration
as I am note using the amp at the moment will leave it alone for now
thanks for the advise
Stan
