Steam powered off grid generator ... perfek! Runs on anything that burns ...
“ The amount of electricity you can generate using a pedal-powered generator depends on a number of biological factors, like your age and fitness level, as well as the efficiency of the generator you are using. An average person capable of producing a sustained power output of 100 W can expect to generate from 31 to 74 W, depending on the efficiency of the generator system.”
So you should be fine with an AC30, or a Deluxe Reverb. Provided you can pedal and noodle at the same time.
Or a THRII plus one of those solar panel car chargers to keep it topped up. Lithium motorcycle battery for your pedals. Easy.
Hmmmm... OK.
Pedals can be run from a USB C power bank into a Harley Benton isolated PSU (for example - mine takes 12V, which a USB C PD power bank can put out). Get a solar one, and it's free.
And, if you use something like a ToneX ONE on your board, it can also run into headphones.
The generator can provide lights, device charging and ice makers. However, boiling a kettle requires about two kilowatts, so you will need gas for cooking unless your generator is truck-sized.
If you are very off grid, wood for a campfire, barbecues and water heating (unless you like cold showers).
You can burn it to generate power
https://www.amazon.co.uk/Panana-Electronic-Generator-Adventure-Emergency/dp/B0C1SQNR1L/ref=sr_1_3?sr=8-3
Could add a solar panel for recharging, if you needed longer duration.
