If so, the five-way selector switch must be a 4-pole, 24-contact type.
The remaining questions concern the resistance values of each pot, whether there is a treble bypass on the volume pot and whether the P90 stack splits when combined with the centre pickup.
If you own a Fretking JV Corona, why not simply photograph the wiring, upload the pics, sit back and wait for ICBM to explain the circuit.
If the OP's guitar has three single coils, most of what I posted yesterday can safely be ignored.
Surely, unless the stock pots were special low friction versions, the new ones will be just as easy to accidentally turn via flailing strumming.
The two basic format options are:
1) dummy coil > selected pickup(s) > controls > output jack.
2) selected pickup(s) > dummy coil > controls > output jack.
If the individual pickups are grounded to the volume pot chassis, Fretking has taken option 2.
The final question concerns whether the dummy coil is wired in series or in parallel with the signal from the selector switch. (This is where photographs would have helped.)
