How to spend £400 budget for bedroom set up
geetarguy85geetarguy85 Frets: 51
edited July 26 in Amps
My current set up is a Line 6 pod go and some AKG monitoring headphones, and also a Blackstsr Fly 3 which is surprisingly good as a tiny portable amp.
I recently moved house and have a spare room that now houses my gear and recording PC, and after years of playing with headphones I've got a hankering for an amp.
I've got a budget of £300-£400 to get something that will be used in the house 99% of the time, with the odd jam at a friend's house. Used gear is fine.
Some criteria:
FX loop
2 channels ideally
Separate EQ per channel is nice, but I know not all options will have this
Needs to work well at bedroom levels, so attenuation could be useful
Preferably a line out or USB out for recording without mic'ing up
Reverb / delay is a nice to have but if not I can put a pedal in the FX loop
I don't have a cab currently so if it's a head then the cab needs to fit in budget too
How would you spend this budget? Some ideas are:
Orange Rocker 15
Marshall DSL 20
Blackstar HT5
Boss Katana 100 or Artist
PRS MT15 and a load box, not in budget though...
Sell the Pod Go to free up another couple of hundred and buy a used helix stomp and an FRFR/powered cab?! This would only really give me the benefit of more DSP
I mostly play hard rock and 2000s metal, but some blues and would like decent cleans to give me flexibility.
Thanks!
  • ecc83ecc83 Frets: 1724
    Well! I am gonna say "HT-5" innit!  But seriously, you will struggle IMHO to find a more versatile and well featured amp* and you could even gig it through a decent 1 or 2x12. You are also only about an hour away from them SHOULD you need service.
    I would definitely go for a head, why pay for a speaker you might not like? (one is haunted by the Rocket 50!) As to what cab and speaker to go for I shall leave to the good offices of chaps like ICBM who has vast knowledge of the many options. He will probably be able to suggest the drive unit best suited to your particular genre.
    Idea: Had you thought of 'miccing up' the cab? If so the Behringer XM8500 dynamic mic is very good for 25 quid or so.
    Do you have an audio interface? If not give the MOTU M2/M4/M6 a serious looky atty.
    *Both it and the HT-1 are reviewed in the current edition of Sound on Sound.
    Dave.
  • geetarguy85geetarguy85 Frets: 51
    Thanks Dave. The main reasons I wasn't thinking of recording via a mic are because I haven't done it before and tbh laziness
  • RevolutionsRevolutions Frets: 783
    edited July 26
    Humboldt Simplifier DLX will do everything you need plus more. And it sounds excellent in all three amp modes (Marshall, Fender, Vox).
    You’d need an FRFR cab if you want monitoring. At home I use it connected to my Adams powered monitors. Bought it as a tiny gig backup.
    I’m probably going to sell mine as it’s surplus to requirements.
  • WazmeisterWazmeister Frets: 9961
    Id try an HX Stomp
  • Winny_PoohWinny_Pooh Frets: 7991
    edited July 26
    These are two seperate things IMO
    -headphones
    -amp in room
    For the first, keep the pod go and use it for recording too.
    For the second possibility an Orange rocker or Marshall sc20, a modeller will not give you the same feel as amp in room. (95% of the time more enjoyable than a modeller into headphones or monitors)
  • TeyeplayerTeyeplayer Frets: 3393
    As above. Orange Rocker or Tremlord (if you want it as a clean pedal/pod platform) for home use and the odd trip out. Keep the existing set up for recording.
  • DiscoStuDiscoStu Frets: 5705
    No idea what it's like and slightly above budget but GuitarGuitar are doing the EVH Iconic 15W combo for £479 just now.
  • JonathangusJonathangus Frets: 4968
    Laney Cub Super?  15W but has a <1W input, FX loop, switchable boost, reverb.  Or the original Laney Cub, but that's just a single channel.
    Trading feedback | How to embed images using Imgur
    As for "when am I ready?"  You'll never be ready.  It works in reverse, you become ready by doing it.  - pmbomb
  • chrisj1602chrisj1602 Frets: 4139
    The Orange Rocker 15 is a great amp and seems to do what you want and is compatible with the genres you play. The lack of EQ on the clean never bothered me, and I’ve had the 15 and the original 30.
    if you like your Pod Go models then the Catalyst could work well.
  • relic245relic245 Frets: 1088
    I'm going to say DSL but get a 40cr not a 20.
    A secondhand one will be in budget if you're patient.
    That model gives you a respectable line out for recording which I'm pretty sure the 20 doesn't have.
    I have the 40cr, it doesn't have an attenuator but the master volume works well and sounds great at home levels.  Plus is you ever do go out and play with others you turn it up and you've got a beast!
    Cleans are great - will it do metal? Depends on your definition of metal but you might want a boost pedal in front to kick it a bit.
    It has built in reverb but tbh it's shit. It's the only thing on the amp but it really is so you would probably want a pedal in the loop too, but you can get a good 2nd hand basic reverb for not much money.
  • PabcranePabcrane Frets: 492
    If you're looking at secondhand ams, two I've had great experience with are the Peavey Classic 30 and the Laney LC15r. I had a quick look online and there are some of both on Reverb and eBay for well under £400 at the moment.
    The Classic 30 might be a bit overkill if you're only using it at home 99 percent of the time.
  • Laney Cub Super?  15W but has a <1W input, FX loop, switchable boost, reverb.  Or the original Laney Cub, but that's just a single channel.
    Good shout. The Cub Super 12 is a cracking amp.
  • DeadmanDeadman Frets: 4105
    Orange Rocker 15. Extremely useable onboard attenuator actually works. Great sounding amps.
  • newi123newi123 Frets: 946
    As a lover of expensive valve amps I'd go for a katana. Recently picked up a mk1 head and footswitch for £180 and it's great. Not great for £180 or great for a digital practice amp - it's genuinely a good amp. Perfect for home and I'd happily gig it. I'm surprised by it.
    Others have said the speakers in the combos are the weak spot - but you could pick up a mk2 100 combo and a changed speaker new for less that £400
    And if you want you can just use it as a power amo for the pod go......
  • pintspillerpintspiller Frets: 1011
    A DSL1 or HT1 would be loud enough for home use. With a 2 x 12 would also be loud enough in a rehearsal situation. Both come with line out
  • SchnozzSchnozz Frets: 2134
    I like the Blackstar HT5R
  • grungebobgrungebob Frets: 3468
    edited July 28
    Today I took delivery of a headrush FRFR08 to use with my pod go. Previously I’d been using the pod go through the poweramp section of a valve amp.
    Really impressed with the headrush speaker. Has Bluetooth too so I can stream my backing tracks or Spotify through it.
    Has really transformed my pod go too.
    I got mine used for under £200.
    I can control the output easily for late night or home alone playing.
    More easily movable too , might not be an issue for you but I’m recovering from shoulder surgery so valve amps etc are no longer in my future.
  • RockerRocker Frets: 5088
    My friend, everyone has their own idea of what sounds good and how they want to sound. Go to your local music equipment dealer and try out amps that are in the shop. You don’t need forum approval to buy a Katana or a Champion or whatever amp. If it sounds good to you, then it is good. Buy it, play through it and enjoy the experience.
    Nil Satis Nisi Optimum
    Thanks all, lots of food for thought here. Of course, I'd like to get along to a music shop and try out some amps, but wanted some ideas of what to try out.
  • TheMarlinTheMarlin Frets: 8385
    Amp in room, this is brilliant, and cheap as chips.
