I'm looking for a second amp with view to having a spare if ever my vintage Deluxe Reverb dies. The weight, price and format of the Studio JTM are pretty appealing plus it sounds good from the clips I've heard.
However, I tend to run my Deluxe clean (around 3 - 4 on the volume) and use it as a pedal platform with enough clean headroom to boost volume over the other guitarist in the band for solos.
So, my question is does the Marshall have the ability to be set relatively clean and still achieve reasonable gigging volumes with clean headroom to spare. For reference, I've had a lot of 15-20 watt amps (predominantly EL84 types) where they fell short because they distorted too soon and any boost = more gain rather than volume.
Thanks!
I've got one recently and while it’s a great little amp mines starts clipping by about 4 on the volume controls. It pretty loud but I’d have serious doubts its loud enough to be gigging with.
As @ecc83 says I think you would need to look at more watts for the headroom.
Best pedal platform I even used was an old JMP Superbass, utterly deafening, sounded glorious
The 22 watt 6v6 Deluxe Reverb has always been more than enough amp for me in any given gigging situation - I rarely get above 3 on the volume (un-mic'ed) and that's with a relatively loud drummer and second guitarist.
What I would say is it cleans up nicely on the guitar volume pot, so you could roll it back for normal and up for solos, bit fiddley, but it's what a lot of 60’s and 70’s did on their Les Pauls – neck for clean bridge full up for roar, pickup selector to change sound.
It really does capture the sounds of the old amp. It is actually only 10 watts less of output power to the JTM it’s based on!
https://www.thefretboard.co.uk/discussion/265828/matchless-lightning-reverb-1x12-15w-combo-1-600-now-1-500#latest
That's good info - never realised why it was the Deluxe could handle gigs far better - thanks!
The 50w Origin is perfect though, and way cheaper.
Or just buy another deluxe reverb or a Carr
