Ebay mark7777_1
In the Render dialog box you get options including what to render (eg time selection), in what format (wav, mp3 etc), and where to (folder destination).
although he does pause
after every 3 or 4 words
which can be
kind of annoying.
Then at the bottom of the box you have which file type to render to. Then click render.
If you can't figure it out step away from it for a bit.
Can you not check the last things you did, and undo?
Is the path to your installed plugins correct??
Have you looked at the Cockos Forum, there is a search function there, so it should be pretty easy to find out if this is a common problem, or something weird that only applies to your install.
Sorry, can't be more help, but usually it is something silly that we have done ourselves, Reaper is pretty amazing software really.
