Getting rid of rust on chrome - what have you used that works?
rze99rze99 Frets: 2504
on a car this time, but need to get rid of rust on chrome. advice please.
  • My mate uses aluminium foil on his motorbikes
  • octatonicoctatonic Frets: 34318
    Aluminium foil works better than anything.
  • rze99rze99 Frets: 2504
    Doesn't foil micro scratch the chrome? It seems counter intuitive somehow.
  • steveledzepsteveledzep Frets: 1208
    Solvol Autosol.
  • ColsCols Frets: 7727
    Make a paste of bicarbonate of soda with water.  Spread this onto the rusted area with a damp cloth, and then scrub with crumpled up aluminium foil until the rust is gone.  Rinse and polish with a microfibre cloth.
  • EricTheWearyEricTheWeary Frets: 16667
    I've used aluminium foil. What it can't get rid of is any pits caused by the rust. Been a while since I've done it but if you are using it like a polishing cloth it shouldn't scratch as it's softer than the chrome. Plenty of options for polishing chrome anyway but the foil will move surface rust.
  • strtdvstrtdv Frets: 2590
    edited August 10
    The problem with chrome is that water vapour can penetrate it and corrode the steel underneath. Once pitted the only thing that will really remedy it is getting it replated by a specialist.
    The EU is banning hexavalent chromium plating so might be worth getting it done while you still can if it's a classic car or similar
  • DeadmanDeadman Frets: 4159
    Solvol Autosol.
    Unbeatable stuff.
  • AdeyAdey Frets: 2802
    edited August 10
    If you have rust on chrome isn't it because the chrome plating has been damaged and the steel below is rusting through the damaged area?
    You might be able to remove it in the short term, but I thought re-plating is the only real solution.
  • Emp_FabEmp_Fab Frets: 25598
    Solvol Autosol is the best chrome cleaner on the planet.
    Offset "(Emp) - a little heavy on the hyperbole."
  • RaymondLinRaymondLin Frets: 12333
    Autosol + 0000 wire wool = shine
  • RevolutionsRevolutions Frets: 949
    I always try to keep my browser window inside the laptop during winter.
  • DominicDominic Frets: 16678
    Anusol .......
  • BillDLBillDL Frets: 9018
    Dominic said:
    Anusol .......
    ...... best restricted to use on the rear end, and in particular the exhaust pipe.
  • HumboldtHumboldt Frets: 74
    The aluminium foil method works well with coca cola as an agent. Don't be too aggressive though as the chrome could scratch.
  • ICBMICBM Frets: 74496
    What are you asking this for on a guitar forum? It’s natural relic’ing, you should leave it as it is.
  • SnagsSnags Frets: 5694
    Unless it's a massive amount of rust, then another vote for Autosol here. Kept many a motorbike in shiny order over the years.
  • LodiousLodious Frets: 2013
    I tried Aluminium foil which didn't seem to do anything on exhaust tips. Autosol worked much better in that application.
    Toothpaste can also give good results on lightly affected areas.
    edited September 23
    OP update. I used Autosol applying both with cloth and soft toothbrush. Patience and a few goes at it is rewarded. V please should have done before and after pics. I expected to find more pitting. It ain’t perfect but very passable.
