Quad cortex users ….
My pal is using one of these with the transpose function but he’s original key and the transposed together….whats the deal ?
Mac Mini M1
Presonus Studio One V5
 https://twitter.com/spark240
Reddit r/newmusicreview
  • digitalscreamdigitalscream Frets: 27830
    Moved to Digital & Modelling - more likely to get a decent answer in there.
    <space for hire>
  • John_PJohn_P Frets: 2763
    Just turned on my QC to see if I could get the same result.     The transpose block only has a pitch control in semitones so it can't be an issue with that block.
    I'm guessing it is a signal routing issue.    Has he added any splits to route the signal down two pathways rather than having it one line?      Is he just connecting the QC straight out to a speaker?
  • spark240spark240 Frets: 2107
    QC direct out to monitors.
    Mac Mini M1
  • onyironyir Frets: 54
    If it's not a routing issue, I would check that he's not actually hearing the acoustic sound of the guitar (you wouldn't believe the amount of times I have seen this question before...). Record something and play it back just to make sure
    He reckons that not the case ...
    Mac Mini M1
    Can we see the patch?
