Not sure if 'm in the right category but here goes.
I am in two bands who could not be more opposite. One is a pub band that uses amps and the other is a function band that is self imposed silent stage (albeit with an acoustic drummer). I cannot get on with in ears so get my mix though a wedge.
For me noting compares to using valves amps. The nuance in my playing and the way I can control dynamics with a valve amp is different league to digital where personally I can feel as though I'm dialling it in sometimes. I get the, "it doesn't matter in a mix" argument, the crowd doesn't care and agree...but valves just hit different. I want to get as close as I can to replicating the feel I get in my pub band with the function band.
I was thinking would hooking a two notes captor x to my head get me closer to the feel of valve amps even through a monitor? Secondly as I use an SV20, would a Sheriff V4 amp work with the Two Notes tech be any different to amp + two notes?
Anyone have experience of either/or/both?
Thanks
I have had a similar experience, I had to use a HX Stomp setup with in-ears and didn’t really enjoy it. It was quite rushed to get the setup sorted so may have had better luck with more time etc. Through a Powerstage 170 and cab, it sounds and feels great.
I can also vouch for the Victory V4 preamps (I have a Sheriff and Copper) with a Two Notes Cab M, which is basically the Captor X without load box, so great for pedals.
I haven’t tried the V4 amp versions, however can imagine it’ll sound great, although the feel may be different due to the solid state amp. The valve preamps are done really well, feel and sound excellent.
Hope that helps,
Cheers
Vince
