... do you find your footswitch jack is "quite warm" when removed at the end of the gig, after you've been running it at a healthy level (channel volumes maxed, masters moderately high) for a few hours?
Not red hot ouch-ouch-ouch, but definitely "Ooh, that's really quite warm verging on hot".
It's something I've only recently noticed, but also until recently I'd mostly only used the amp for practice, so wasn't packing up at the end of a session. So not sure if it's a design feature or signs of a potential issue. I'm assuming the former, as the thing has just been to a local, respected, amp shop for a new switch and a general check over, and they gave it a clean bill of health, but ... paranoia kicks in!
On mine, the jacks are flown out on to a daughterboard that's mounted very close to the main board and the output valve bases. There'll be a bit of heat there, plus from the screen grid resistors nearby.
If it's bothering you, maybe you could get your guy to check it out with that specific concern in mind?
Such a glorious sound when you can turn it up a bit!
Turn off the amp
Pull out all the cables and let them fall to the floor
Move the amp and cab extension out of the way
Pack up pedalboard
Carefully Coil up all my cables
It could be by the time I get to them they've all cooled down, or they don't get that warm.
I'll check at next gig.
Make sure air can get around the amp and vent on the back.
