LDSystems LD10 active Speaker x 1 and a half
maltingsaudiomaltingsaudio Frets: 3867
edited September 2024 in Studio & Rec £
LD Sytems LD10 active speaker, about 200 watt with two channel mixer. It’s about 10 years plus old . Has a torroidal transformer as opposed to more modern switch mode supply.I have two,of which one has a speaker which is farting badly so needs replacing ,and one is up to snuff apart from a cabinet repair. Speaker you will need is 10” 200 watt 4 ohm.Can put phots up if needed.
Need the space as already replaced,so the pair in protective covers which are ratty for £100.
Won’t post due to weight I’m in Shepton Mallet
www.maltingsaudio.co.uk
