marktheharp
Frets: 103
LOL 0
Wow! 0
For the same reason I haven't tried the coated Fenders.
If you are looking for good cheap coated strings, I recommend DR Veritas (£8.50), GHS Americana (£9), and Rotosound Nexus (£12). Also consider the uncoated Dunlop Phosphor Bronze at £6 which are very stiff and hard under the fingers and, for that reason, last for ages and ages (if you can cope with the muscle required).
Rough rule-of-thumb: hard, high-tension strings last longer than softer ones. Of those I listed above, the Rotosounds are probably the longest-lasting but also the highest tension. DR Veritas are rather special in that they last well but, being essentially the same as DR Sunbeams only coated, have that lovely Sunbeam feel.
Last point. Many people like the sound of nickel or monel strings on all-hardwood guitars. If this is you, then a set of D'Addario Nickel Bronze (£10) or Martin Retros (£14) will last practically forever.
