Hx One flux and expression pedal question
satg64satg64 Frets: 23
edited October 2024 in FX
Hi, does anyone have experience of this HX1 assigning parameters : can flux be assigned to a parameter and at the same time can the expression pedal be assigned to a different parameter ? In example: delay, setting flux controls the feedback, and the expression pedal controls the volume or the mix of the effect. At the moment, I cannot see a way of assigning flux, and expression pedal, to two different parameters at the same time. The flux button and the expression pedal seem to always control the same parameter. I would like to be able to control two different parameters. Thanks for reading this, and I’m hoping someone can solve this for me.
  • EricTheWearyEricTheWeary Frets: 18288
    Looking at the manual (I'm on a train, it's passing the time) although it doesn't seem to explicitly say you can't do any of those it only gives instructions for changing one parameter so I presume that's all you can do. Some effects have a parameter set as default although that can be changed.
    On the Studio Rats channel they used a delay as a boost but having a quick look at that it was still one parameter (the delays have a built in volume parameter so you can use flux/expression to act as a clean boost when you already have a delay on).
  • satg64satg64 Frets: 23
    I phoned seller Guitarguitar to ask this question.. and the guitar department salesman was unaware that it couldn’t be edited with helix desktop editor
    Line6 say no. I’ve submitted it as a suggested improvement. Along with the ability to select saved presets silently. And asked that the presets retain their name when selected. At the moment, they display the original name of an affect given by Line6.
    These are hugely important and it’s honestly quite odd that L6 didn’t get onto both of them within weeks of launch. In combination they’re the reason the One doesn’t work for me
    It is a real problem for me, not being able to see the tiny display easily . The fact that the display does not maintain the name I have given to the edited preset when selected. My workaround is:  I am using a midi pedal to select the effects (that pedal only displays a number).. ..  which is ridiculous because it’s the same size as the HX one which is meant to save pedal board real estate. it’s not actually on the board it’s next to it on the floor. Not great either.  And the only way for me to know what I’m doing at live show is to write out on a big piece of paper the name I’ve given to  the effect and the preset number for the midi pedal and have that on the floor next to the pedal. But never the less  It is a good Swiss Army knife.
