I’ve got a Mooer baby bomb which is great apart from the hair trigger volume control. It goes from nothing to ear bleeding if a butterfly passes with 15 feet. I’m putting it in a little box with my pod express for a travelling about rig. I could fit a volume knob between the pod and the bomb but it’s another box.
I’m contemplating an EHX 5mm ( as it’s 2.5 watt I’d image the pot is a bit more controlled, and it runs from 9v so one little power supply or even battery pack). I don’t need masses of power for this but more controlled volume is a must.
any ideas. Just get the 5mm ? Try a different pot? Mod the baby bomb into a slightly larger enclosure and fit a pre volume ?
Have it plugged into a 60 watt 12 inch cab, 8 ohm. I didn't expect much, and the spec on it is for headphones, so 16 ohm and up, but it is plenty loud enough at half volume, fed by a Tonex one, runs for a couple of hours on battery - but works plugged into a phone powerbank, which also powers the Tonex.
Was just an experiment to see if it would work, which it does quite well actually.
EHX Magnum
SD Powerstage
Quilter
Harley Benton (multiple options)
Foxgear
Laney Foundry
Orange Terror Stamp, Pedal Baby
Valeton mini head
TC BAM 200 mini bass head
Crate Powerblock
…I’m sure there are many more but anyway, how do I decide? I’m really struggling. It does make me want to sack it off and spend the money on a Fender TMDR. But that’s essentially a modeller into a class D with a speaker.
Bluguitar
while that’s happening I’ll jam an o-ring under the knob and keep my eyes peeled for an alternative solution. Maybe a FRFR of some kind, it doesn’t need to be huge either so I may build something.
I do wonder if there are plans for a tube power section out there? ( for no other reason than I like building stuff)
or, along the lines of the bass amp solution above, a small bass combo with an effects loop. I have this idea that a bass amp has more clean headroom than a guitar amp ( I’m probably wrong)
Sorry to hijack the thread somewhat - it’s just I’m looking for a similar thing - @Exorcist re the Warwick Gnome - have you tried a BAM200? What’s your point of reference? Would I be satisfied looking for a big clean sound a la Fender Twin?
Ive just put a bid on a Tech21 Power Engine cab , if i win that it could be a decent solution
I'm going to list it for sale @ £50 plus a fiver to cover post.
https://www.cashconverters.co.uk/shop/music-tv--video/musical-instruments/accessories--spare-parts/guitar-accessories/044800125803
its not a mega bargain but its cheaper than a new one
