Here's some live gig clips using my Vox Tonelab LE through a single FRFR108 mounted on a tripod on the left of the vid. My last band were pretty loud and the FRFR108 was only around half way!
At some level, every person we see talking about gear is always buying something new, otherwise what is there to talk about? I don't think that means anything specifically about their past gear.
I miss the craziness of a valve amp, but the ability to just plug in, switch on, and play is great. Also my back prefers it.
The reason I prefer an FRFR solution is that I use a piezo equipped electric and a Boss SY-200 on a few songs in the set and these benefit massively from running through an FRFR.
The Fractal sounds great on core guitar tones so I get the familiarity of a traditional backline amp with greater flexibility.
The Fender is plenty loud enough on its own for pub gigs but I usually feed a bit of signal into the PA to help spread the sound a bit - the Fender does the heavy lifting though. Might be unconventional but it works for me.
You need monitoring to hear vocals etc so just use that.
We did try using IEMs and no back line on stage ... its not for me lads
I do actually have a Headrush FRFR108 which we have been using in the band as a general monitor. It never occurred to me to stick it behind me and use it as backline, but I see people above in this thread doing just that. So, that's something I should definitely try. I do feel there's something a bit odd about having a PA speaker on a pole behind me rather than a 'proper amp'. But I wouldn't want to drop £100s on a Laney LFR just for that reason alone. It would need to sound better. I'm struggling to find comparisons of these things online. There is this one:
When I first listened to that my instinct was the Laney sounded 'bad'. Listening back though, with proper headphones, it's not so much that it's bad rather than it has a huge amount more mids, I think. Which, if other comparisons between real cabs and FRFRs are anything to go by, would suggest the Laney sounds more like a real cab. I could be wrong. One thing is for sure - they sound hugely different.
It's linked above isn't it? This should work: https://www.youtube.com/watch?v=3dhyDPzMLUI
This doesn't matters quite so much in a guitar context with not much going on below 80Hz but make the active speaker too light and the whole thing will move because for every action there's a equal and opposite action. The cone moving forward tries to push the cabinet backwards and so forth. Basically you want the cabinet immovable but that's not really practical.
There's a certain sound I hear with some of the modern plastic housed tops like FBT and such. You can go too far making things too light in PA
