This one in particular
.https://www.ebay.co.uk/itm/395937728467?_skw=Martin+000-42+Acoustic+Guitar+-+Natural&itmmeta=01JDVPEJN7B39ARWMSYDDTS4N2&hash=item5c2fba47d3:g:keUAAOSwK01nRIV0
I would get in touch with a guitar repair guy and ask their opinion
A waist repair is straight forward: I got one done a couple of years ago for around £40. Will, no doubt, be higher than that now. I would dig into the UMGF and read up on all posts on this specific binding issue or ask the question, should there not be anything there about it (highly unlikely).
The question is whether it's now stabilised. If it has, really all you need to do is cut a tiny piece of ivoroid/black/white binding and glue it into the gap. If...
I'm also surprised that if this is the cause, the top hasn't cracked roughly under the low E string - the expansion of the fingerboard will have put a lot of stress on the top under it which it's glued to - even though it's not as much as you might expect, the gap in the binding is at 45º so it will be roughly half that amount. My '71 D-35-12 has the typical top crack under the B strings due to the old pickguard having shrunk. (They're notorious for it - it's been replaced now.)
