Advice sought. Loss of high end in simple switch
jakeollyjakeolly Frets: 139
edited November 2024 in Making & Modding
Embarrassing . Iv3 made a v simple pad switch to switch guitar from amp to Mac interfacec
 it’s made both signal paths v. Muddy
being cheap I wired from some ( old) studio spares signal cable and single strand bits
what have I done wrong ( apart from being* rubbish ( at soldering ) it’s not noisy, just bassy/ dull
https://imgur.com/a/Oet7cDR
  • ICBMICBM Frets: 78193
    Used shielded cable inside a metal enclosure - totally unnecessary.
    The secondary thing is that you've probably not stripped the semi-conducting shield layer of the shielded cable back far enough, and it's touching the solder at the terminals - the symptom of that is always a very dull signal, usually with some loss of volume - but I wouldn't bother trying to re-do it to fix that, just get rid of all the shielded cable and rewire it with plain.
  • jakeollyjakeolly Frets: 139
    Thank you, I didn’t know what to do with the black shield layer, and yes , about 3/4 db of signal drop too
    never new about that
    thanks mate, much appreciated
    there goes my Saturday morning :)
    Wizz awarded
    Don’t feel bad about not knowing, it’s easily the most common mistake when working with shielded cable and you’ve never come across it before. Been there, done that… it baffled me at first too.
