You've had some work showcased here. It's awesome!
Agreed re Jooky, too. Looking forward to getting him back, a wonderful man is Jooky, who first got me into partscastering a couple of years ago on musicradar.
Frankus on this forum kindly sent a Bass VI up to have the Woodtone finish stripped and refinished in blue.
So first bit of knowledge I can contribute is that Woodtone is not too difficult to sand back to clean wood. :-)
Here's a close up of a mod that may be of interest though.
The guitar is an SG Junior copy that usually has a Mojo P90 installed (it has a Mojo wiring loom.)
Personally that's all I need-keep it simple.
Doesn't stop me from tinkering though so in goes a cheap Tiesco(?) pickup.It's a lowly 3.7k,dull and weak sounding but raising it so it almost touches the strings brings out it's potential when cranked.As a low-fi gnarly one trick pony it works surprisingly well.
Hopefully you can see in the picture the faint outline drawn around the dog-ear pickup cover.The cavity "lobes" were enlarged very slightly to accept the Tiesco pickup mounts.So it was a worthwhile experiment and easily reversed.
Hope this helps fellow modders.Thanks.
http://www.thefretboard.co.uk/discussion/25093/raygun-relics-incredible-work
and after I'd seen Jooky mention you on his blog - I knew what I was going to do
I'm not sure which feels most embarrassing- all the praise or the picture of me gurning in the cluttered back room :-)
