FS: 2x12 ATA Flightcase
CirrusCirrus Frets: 8563
edited March 2015 in Amps £
Righty,
An amp I recently bought (Mesa Stiletto Ace combo) came with a flightcase that I'm not going to use. The amp was bolted to the bottom and there's no foam padding inside so while you'd need to stick your own foam in it would give you a bit more leeway in making it fit a 2x12 combo/ cab.
£45 + postage. Meeting up in person probably makes the most sense given the size of the thing, though.
