Signal flow INSIDE a Helix...?
@Digital_Igloo @rossyamaha ;
This came up on the facebook group.
As I understand it... Guitar > A2D conversion > tone shaping > D2A conversion > Out to XLR etc.
But what  happens with the USB when using the helix as an interface?
Is the USB signal taken directly after the Tone Shaping bit before the D2A conversion, or does it get taken AFTER the 'spur' to the XLR and then goes through another AD conversion so it can go into a computer?
In other words - if a person connects the helix to an external interface using XLR is the total number of AD/DA conversions the same because the "to the USB" bit in the Helix is not happening?
Does using a separate interface introduce more latency, irrespective of how small that is?
In my amazing diagram - is USB Option A accurate or Option B which has another conversion process?
Or is there something else?
ta
Attributed to Albert Camus
https://kottracker.com/
  • Danny1969Danny1969 Frets: 12533
    Normally the serial stream for the USB is created from the digital bus before any DA conversion. To do otherwise would be stupid. So A
  • fretmeisterfretmeister Frets: 29521
    That's what I would expect but someone on facebook is claiming otherwise.
  • stickyfiddlestickyfiddle Frets: 33157
    Surely it’s A?
    Does this person on Facebook have any reason to believe it isn’t?!
  • SporkySporky Frets: 36814
    Then it must be true!
    Surely it’s A?
    Because he says he gets the same latency from Helix into a separate interface as he does when just using the helix as the interface via USB. First he claimed that there wasn't 2 rounds of AD/DA conversion, then said it was negligible, and now seems to be unaware that adjusting latency settings in a DAW doesn't affect the internal operation of the helix.
    He actually claimed that helix had zero latency because if it didn't then modelling would have died years ago. I showed him a post from Digital Igloo where it was stated that total throughput is under 2ms and that using the loops increases that.
    Only then did he say - so we all have latency then...?
    I asked what he was using to measure the latency - it seems that he's trusting the sliders in his DAW rather than using a O'scope plugin or similar.
  • If you use all 4 of Helix's fx loops, with a digital pedal in each loop, you could wind up with 18 digital to analogue/analogue to digital conversions between your guitar and the output of the Helix ...
  • jellybellyjellybelly Frets: 937
    Sounds like that Dunning Kruger fella has been up to his old tricks again
    I might point that out.
  • RolandRoland Frets: 10146
    Surely it’s A?
    Because he says he gets the same latency from Helix into a separate interface as he does when just using the helix as the interface via USB…
    You can get latency if the digital sample rates are different.
    • 44.1 kHzThe standard sample rate for CDs, often used for music related files.
    48 kHzA common sample rate for audio associated with video. It's also the default sample rate for many Bluetooth devices.
