guitarmansteve77
Frets: 179
LOL 0
Wow! 0
However....https://www.gak.co.uk/en/fender-engine-room-lvl12-power-supply/942154?gclsrc=aw.ds&gad_source=1&gbraid=0AAAAAD_lAC8X3V_G9UuunvGH7YmQOQBQd&gclid=CjwKCAiAzba9BhBhEiwA7glbaoFf0bL4le5leicE5wIhDoZ3ZVkWwWASCuPSPWzneVsQz8KahDzUvxoClZUQAvD_BwE
Could use the Cioks 7 with that method I guess. Which type of pedals are best to couple together?
The way I'm thinking is that pedals typically take power from either a small internal battery or external supply. The battery provides beautifully clean DC power, and as we all found out, most small AC adapters produce considerable distortion, which at this point is not allowed.
I'd like a pedal array to have power supplied directly from a large battery. That way the noisy AC does the charging and the quiet battery DC does the audio. Simple solution would be a camping power block. I could also run an amplifier, and make tea.
I'm not sure if I've explained my concept very well but does it bring any products to mind, or should I be looking for venture capitalists to invest in my new product?
The yard is nothing but a fence, the sun just hurts my eyes...
Cioks make good kit but I don't like that they use a different plug rather than just using the 2.1mm at both ends.
Also don't be afraid of daisychaining analog dirts, tuners, etc. 99% of the time you can do this for 3-4 pedals on a board without introducing serious noise.
https://www.thomann.co.uk/harley_benton_powerplant_powerbank_mk2.htm
https://www.thomann.co.uk/mission_engineering_529i_recharge._power_supply.htm
https://borrowedtime2.bandcamp.com/
I don't mind the different connectors now I have Cioks on 2 boards.
