Bassman clone: from blackface to silverface
RevolutionsRevolutions Frets: 4340
edited March 2025 in Making & Modding
Here’s my Balls BF-50. It’s a single channel Bassman 50 blackface circuit with master volume & no bright cap. Chassis is about as small as possible with this 50w circuit, reason being it makes things a million times easier commuting to practice & gigs with a smaller sized box
Something about the breakup/pushed preamp sound just isn’t working for me, so I’ve decided to shift it closer to silverface spec, which is a sound I know & love.
After a chat with the builder, he suggested a few simple tweaks that will get the tone stack closer to the 70s sound.
Frustratingly, I can’t start today as one of the replacement caps is far too big to fit. I need a minimum 350v cap & stupidly forgot that 500v are mahoosive. Will update on progress next week, just thought I’d pop these pictures up as the builder’s work is incredible.
  • LoobsLoobs Frets: 4809
    edited March 2025
    Very very cool, amazing build quality. I follow him on IG, love his designs. Funnily enough my main touring amp is a 70s SF Bassman 50 (pic 3).
  • RevolutionsRevolutions Frets: 4340
    Lovely setup. Love Les paul into a silver face bassman  <3
    I’ve got a few fuzzes from Tony as well as the amp. His work is impeccable. I’m probably going to commission a JMP 2204 in smaller form later this year. Getting a 50w head that bit smaller helps with travelling on the tube.
    Hey, thanks. I'd love to see that 2204 when you finally get it made. I should check his stuff out in greater detail. Would he build me a really small, low-wattage head? 5w or so?
    He would - in fact he's just built an 8" Bassman meets champ for a friend of mine. He did specifically mention that small builds cost more or less the same as a 50w amp, fyi.
    "AB165 Bassman-based circuit with added reverb and bias wiggle tremolo. The back end is two ECL84 tubes, cathode-biased for ~2 watts. Gorgeous looking and sounding Jupiter 8SC 8" speaker. 17" x 13.5" x 7.75". Intended to be a house amp that sounds like bigger push-pull amp."
