Was I hasty in rejecting this nylon string guitar?
PauloPaulo Frets: 65
edited November 2014 in Acoustics
I went to look at a nice Admira guitar going cheap this week and it seemed to have an ever so slight upwards incline in the neck round the first 4 frets. Is this normal? My own Yamaha cg150 is dead straight, but the Admira was a higher spec and I was so unsure that I walked away. I wasn't even sure if it was just my eyes playing tricks. But for those of you who play higher end classical guitars is this something you should see. The amount of upward bend as it appeared was very small.
  • sounds like it just needs a trust rod adjustment to get the desired amount of relief.
    The action is usually lower around the cowboy chord area (due to the bow)
  • VimFuegoVimFuego Frets: 15842
    hmmm I was always under the impression that classical guitars don't have truss rods.
  • PauloPaulo Frets: 65
    They dont
    my 2 do.
    but they are modern takes :-)
    Dont the amira have an adjustment in the sound hole?
  • Had a look at my Admira Capricho.
    Can't find any form of neck adjustment inside the guitar.
    No truss rod either.
    Hope this helps.
  • That is probably why it is going cheap. Admira are not really high end My  instinct says avoid at all costs
