I know the correct answer is to crank and use the volume knob on the guitar, which I happily do during waking hours. But I'm wanting to have an option to get my Two Rock Burnside past noon on the volume, without shaking the walls too much (or at all).
So I guess that's the first thing to stress here - I'm not trying to get cranked tweed tones at bedroom levels. I'm after a nice natural compression and break up at lower volumes than I normally need.
I'm considering either getting a tweed style pedal (A Les Luis for example), or going down the attenuator route - currently eyeing an Iron Man 2 Mini (8 Ohms only is annoying but I have an Alnico Blue speaker I could swap into my amp to make it compatible). A cheaper option, and one I could mount inside the amp would be Dominics Dr Z Brake Lite that is for sale on here.
Wondering if anyone has had experience taming a tweed going down either the pedal route or the attenuator route - in which case I'd love to hear any advice or recommendations. I hear that certain attenuators are better with certain amp styles etc, so in that case I'm wondering which might be best suited to mine.
Cheers!
I don't think a pedal will give you the same sort of compression, unless the amp is already overdriven as well. So the answer is probably both, but attenuator first.
As I mentioned, there is a brake lite for sale on the forum but I’ve also had someone PM me with a trade offer for a their Ironman Mini II (for one of my pedals listed in the classifieds).
@ecc83 so if I’m understand you correctly - the 8ohm rated ToneKing is really only referring to the amp? So as long as I run it through the correct output, I can still use my 16ohm speaker with it?
Now it’s simply deciding which attenuator, trade for the IronMan or buy the Brake Lite.
https://www.youtube.com/watch?v=QrRRjIIT_OM
So I set out to once again experiment with my Tweed Deluxe and from employing a very unlikely Hi Gain overdrive companion (NUX Amp Sim) I stumbled on a cool trick. I unjumpered the channels (something I have always done as 'everyone' has said gives the best drive tone) and setting the amp volume to the lowest it will go without cutting out, then using the volume of the Amp Sim to lift the level, results in all the juicy Tweed tone without ear splitting volume and bluster. Adding my Tremolo pedal also helps here too as gives an additional volume push in a lower frequency band that helps balance out the overall signal. So I can get that vintage Tweed Vibrolux /Strat sound shown above (and then some) and save £5,000.
He does beat me on having a vintage car collection to play amongst though
There's also a neg feedback/bass cut mod on Robinette's website you can add on a 2 or 3 way switch to tighten up the overdrive. Works nicely to clean up some hairiness.
I'm a 5e3 owner (custom build) and I use an attenuator to get the sound I want at the volume I can use at the time which makes it great for a studio and home use to get "that" sound. A dirt pedal still sounds good but it's different.
