I made this little head which is essentially that but has a switchable port that can accept a DSP module. When the modules switched out of the circuit though it's essentially an SD PS170 operating in stereo mode at 50 watts a side rather the bridged mono mode that SD uses ... I think modellers sound better in stereo so made mine stereo.
Excuse the crudeness of the design, it's a prototype and forget the plug in module .. that doesn't get in the signal path when the amps being used with a modeller ... but it is useful when you need something small to take to a jam in your guitar case
Realistically, it'll cost more than most modellers, but it'll come with so much hype that you won't be able to even look at YouTube without seeing an ad video for it.
And, because nobody will be running it right up to the red line, it'll sound no different to the same modeller running into a PS170.
great invention
