LOL 0
Wow! 0
sounds a good way of logically going about it
Just pull the phase inverter first - usually nearest the power valves. If the noise doesn’t stop it’s a power stage problem. If it does, pull each preamp valve in turn by itself, with the others still in.
So you should be able to see the problem - pull all three preamp valves and the voltage at N3, N4 and N5 will rise to 465V because there is no current draw down the B+ chain - this can cause the caps to fail, even though it's only just over the voltage rating, as they will have got conditioned to operating at the lower voltages. This is *not* bad design - there was no reason for the designers to think that the amp would ever be operated like that, so no need to rate them higher than 450V or use stacked pairs.
Yes, if you use 500V caps throughout this theoretically isn't a problem, but they were not easily available for most of the history of guitar amplifiers - 450V was the highest, and most higher-powered amps use a higher HT voltage than that. Even then, it's surprisingly common for the cap at the end of the chain to fail.
I learned this the hard way by the way
Counterintuitively, pulling all the power valves is in fact safe as it will cause the voltages to rise by only about 10V at most, probably less - there's not much resistance upstream.
It never occurred to me either until the first time I was testing an amp with all the valves out - I can't even remember why now, it was about 30 years ago - and a filter cap went pop! Quite a learning experience - luckily I've always been the sort of person who finds out *why* something went wrong.
Note for Dominic though, mines anything but dark tbh, dialling out a bit of fizz usually!
The yard is nothing but a fence, the sun just hurts my eyes...
