Apologies for the clickbait title. Gotcha!
I've had a love/hate relationship with my Magnatone Super 15 for nearly two years. On paper and from YouTube reviews, it seemed perfect: 15 watts, excellent MV, marshally-gain structure, compact and lightweight, with features like a dummy load and headphone outs—ideal for late-night jamming. It's a boutique piece and is proper cool to plug into.
However, it didn't sound like the videos. The amp had a piercing mid-honky tone and "gravelly" gain structure at low amplitudes that was unpleasant. Hoping to fix this, I replaced the speaker with a UK Greenback, which helped slightly but didn't solve the issue. I battled with it on and off for nearly two years.
I finally decided to sell the Magnatone and invested in a new amp and cab, spending around £1k, expecting to recoup from the sale. Along side this project, I started rebuilding my pedalboard. As I did I discovered tone suck due to my old cables. A buffer helped a bit, but not enough. Testing pedals and cables, I found my main lead—at least decade-old, 4m+ long cable—was causing the issues.
Switching to a new Mogami cable transformed the sound completely; the mid-honk disappeared and the gain smoothed out. I was shocked; it sems a bad cable was the culprit all along.
Once I thought to test the cable I had very much expected it to be an issue of dampened high frequencies, but never in a million years did I expect the cable to impact the tone of the amp in that drastic of a way. I thought at most it would sound like a blanket was laid over the amp, but not anything like I experienced.
Has anyone else experienced such drastic tone changes from a cable swap? Can cable capacitance really cause these issues or did I just have a really good day with the amp yesterday and my ears are playing tricks on me?
Trading feedback here
Capacitance on the other hand is very much in the range where it will make a noticeable and even quite large difference, especially with long cables - including coiled ones, which are actually around 3-4 times the unstretched length.
A honky midrange tone could be just a cable with very high capacitance, although a fault might do that too - the type of cable with a semi-conducting shield layer is prone to this if the layer either touches the solder joints at the ends, or the cable gets crushed or kinked and the insulator splits.
The yard is nothing but a fence, the sun just hurts my eyes...
Aye - I just dropped into nerdiness and thought I should mention them for completeness.
I think my leads are all consistent but this thread has inspired me to actually check that's the case
BUT when an amp is designed, the effects of the cable are taking into consideration and implemented into the design. The guitar pickup, the cable and the amp are all designed for as a whole. So a typical amp like a Fender or Marshall sounds great with a normal guitar cable. It doesn't need wireless or to be made from Russ Andrews nasal hair for the amp to sound good.
But the capacitance very much does matter, because a typical cable will be a few hundred pF or maybe just into the low nF range - up to about a tenth of the value of the tone cap in the guitar, and much higher than the input capacitance of the amp.
With speaker cables, it’s the resistance that matters, because both the source and load are a few ohms, or just into the low tens, so a cable with say half an ohm resistance will make an audible difference. Capacitance and inductance are now irrelevant because the inductance of a speaker voice coil is huge, and the capacitance and inductance of an unshielded 2-core cable are microscopic. Even then, once you get below the resistance of a fairly decent gauge cable and it becomes insignificant relative to the rest of the circuit, it makes no further difference.
And with mains cables the only properties that matter are that it’s adequately rated for the maximum current draw of the amp, and doesn’t break
But if you want you can spend thousands on cables that defy the laws of physics… presumably that sort of magic costs.
