bad code dept
I found this just now:
int hexToChar(char c)
    char hexToCharResult = '\0';
    if(c=='0')
        hexToCharResult = 0;
    else if(c=='1')
        hexToCharResult = 1;
    else if(c=='2')
        hexToCharResult = 2;
    else if(c=='3')
        hexToCharResult = 3;
    else if(c=='4')
        hexToCharResult = 4;
    else if(c=='5')
        hexToCharResult = 5;
    else if(c=='6')
        hexToCharResult = 6;
    else if(c=='7')
        hexToCharResult = 7;
    else if(c=='8')
        hexToCharResult = 8;
    else if(c=='9')
        hexToCharResult = 9;
    else if(c=='A')
        hexToCharResult = 10;
    else if(c=='B')
        hexToCharResult = 11;
    else if(c=='C')
        hexToCharResult = 12;
    else if(c=='D')
        hexToCharResult = 13;
    else if(c=='E')
        hexToCharResult = 14;
    else if(c=='F')
        hexToCharResult = 15;
    return hexToCharResult;
  • frankusfrankus Frets: 4719
    the crazy - hasn't he ever heard of case statements ;)
  • apart from all the other obvious faults, what it actually does is the opposite of its name
    that was my funny ship.
    I thought you were commenting on the elseifs
  • martmart Frets: 5213
    Beautiful. There is so much wrong with that code. He must have spent hours putting all that wrongness into what would originally have just been a line or two!
    or even just a library routine call
  • equalsqlequalsql Frets: 6374
    edited November 2014
    Yea.. should have used a 'select case'  method instead  ;)
  • jellyrolljellyroll Frets: 3074
    This is obviously an in-joke for computerists.
    he's returning a local variable out of scope, thats the biggest sin. I've seen people sacked for that.
    actually he's not .. my bad - not coded C for a long time :)
  • If I had to do that by hand (no library routines available), I'd say
    int HexCharToInt (char c)
      int result = 0;
      if ((c >= '0') && (c <= '9'))
        result = c - '0'; // numeric
      else
        c &= 0xbf;  // to upper, if alpha
        if ((c >= 'A') && (c <= 'F'))
          result = c - 'A' + 10;  // hexchar
      return(result);
    other trickery might get you tighter code, but this is efficient enough, copes with upper and lower case, and is quite perspicuous about its purpose and method.
    but in context, I think he's calling it per character in a string. so why not pass the string address into the library routine atol ?
    can't you just subtract a number from ord?
  • imaloneimalone Frets: 748
    Though I'm not sure what the name actually should do when you analyse it closely either...
    Strictly speaking I'm not sure there's a standard C function that does this (character, not string). There's a very quick cheat if you can guarantee ASCII, though you lose a bit of elegance if you properly generalise it and check inputs. Bizarre way to initialise the result all things considered.
    (Edit, A-F aren't guaranteed contiguous... though it'd be an evil character set that broke that.)
    If I understand your question, the answer is no because the space you're decoding from is not contiguous. The number by which you nobble depends on the range of characters you're nobbling from.
    Eh?
    jellyroll said:
    Eh?
    That's 65 in ascii.
  • mart said:
    jellyroll said:
    Eh?
    That's #41 in ascii.
    fixed that for you
  • HootsmonHootsmon Frets: 16282
    I had a bad code but benylin and some aspirin cleared that Mother up
    tae be or not tae be
    Sounds like you're still bunged up a bit  >:D<
  • I found this just now:
        if(c=='0')
        else if(c=='1')
        else if(c=='2')
        else if(c=='3')
        else if(c=='4')
        else if(c=='5')
        else if(c=='6')
        else if(c=='7')
        else if(c=='8')
        else if(c=='9')
        else if(c=='A')
        else if(c=='B')
        else if(c=='C')
        else if(c=='D')
        else if(c=='E')
        else if(c=='F')
    Ohohohoho.  What a plonker.
  • @Cacofonix that's a lot more polite than my reaction
