I usually use my Tonemaster Pro straight into the front of a valve amp to try to keep things simple.
Last night I went to rehearsal and none of the amps in the rehearsal room were working. I quickly improvised and added a deluxe reverb model to my general preset and plugged into the PA (mono only).
Wow. Sounds were much better/clearer. I could hear myself much better and (possibly) the tone was better.
I had always assumed that a real amp would sound better and would be simpler, but actually going into the PA was easier and sounded better.
You live and learn!
I`ve tried the Lion with the cab sim off into a class D power amp and guitar cab - tbh I prefer it with the cab sim through the FR12.
I`m not ready for straight to PA and no stage volume - I still like an `amp` on stage.
I bought this rig as a light weight solution primarily - but the sound out FOH is the best, and certainly the most consistent, I`ve ever had.
I have found that keeping the gain on the mixer low and having the level slider high does help. I also find that some of the modules in the mixer can be a bit erratic and often the solution to your sound being harsh on input 7 is to change to input 8.
A few years old now, but here's a vid of Nita Straus talking about how she uses a Boss GT1000 live for smaller gigs (& her smaller gigs are probably bigger gigs for many of us!)
