thank you all though for your kindly offered help
if i ever do decide to give up music though i will consider your drumming suggestion!
the new Variax is still piezo, but also has proper pickups to use as a normal guitar i think. They said at the repair place today the minimum starting price for a transplant would be £220 for the work, depending on difficulty if the body donor, then I'd have to buy a donor body (£150 for a new Squier, maybe £200 for second hand Mex if lucky?), plus Variax donor, probably another £150 say, so its looking like £600 probably giving them a bit of leeway for labour. Hmm
or get a 500 or 700 model, but it would have to be local i think as i don't trust line 6 second hand at all, I'd need to get it somewhere i can take it back to if it doesn't work. Been burned with my last Variax and a pod x3 before like that
would have to sell my Tele though in this scenario, also sure what I'd do with the pups if i used it for a transplant. Purely from a money view, if i had to lose the Tele, id get nothing for it compared to the money ive spent on it as its only a squier
keeping my thumb in the string all the time causes all kind of pain though, not sure I'd agree that the amount of noise i get is normal just because its less if i touch the strings. Touching strings interestingly didn't make that much difference if any on the headphone amp, only through the proper amp, which I thought odd. The buzzing through the headphones was painful to my ears and seemed as loud as the guitar tone when strummed it around the house.
Where sells blank bodies? I don't want to have to fanny about finishing one with paint and stuff. I'd use the Pacifica i picked up cheap but I'm not sure if i have a dud or not as it doesn't seem as good an instrument as id heard talk of!
if anybody wants a squier butterscotch Tele with upgraded pickups, you'll need to be able to catch as I'm about to throw mine out of the window
Wiring yourself to the guitar bridge is no more dangerous than touching the strings, but should never be necessary since you'll be touching the strings anyway...
Thanks so much for your help with this ICBM, i owe you a drink if you're ever in Brum
Looks like wireless will help solve this then which saves me playing with my bare feet toucking a pedal!
My Wireless unit literally was a "bargain bin" thing but depending how it goes may upgrade to a nicer newer model, however for now it works so I don't need to. Only real thing to bear in mind is that I'll need to keep a fairly regular supply of 9v batteries. But compared to the amount they would have charged for shielding my guitar that is a small price.
Going to try adding pedals into the signal chain this weekend, and try using it with my multifx on headphones, Exciting noiseless times!
