Zooming on mobile - accessibility issue
The code for the mobile site contains:
<meta name="viewport" content="width=device-width,minimum-scale=1.0,maximum-scale=1.0">
Can we remove the maximum-scale=1.0? It disallows zooming in on mobile and my ageing eyes are finding it harder and harder to use the site.
It would be good if the site was responsive then this wouldn't be a thing (assuming it worked on "desktop").
  • maharg101maharg101 Frets: 861
    Agree with the suggestion, but as a workaround, can you zoom the site via browser settings ? For example, in Brave browser on Android, there is a Zoom setting in the context "three dots" menu.
    This one goes to eleven
    Trading feedback here
  • topdog91topdog91 Frets: 1174
    Possibly, it's just more painful than pinching or whatever the zoom gesture is called.
    Better in one respect though; you don't end up scrolling back and forth horizontally to read a post ;)
  • digitalscreamdigitalscream Frets: 30623
    No, because the mobile site is irrevocably broken if that's removed.
    The new site will be (is) responsive.
    <space for hire>
    What happens to it? Removing the parameter shouldn't do much unless the user zooms in.
    edited May 26
    On 90% of mobile browsers, the layout completely goes to shit and posts are overlaid on each other such that the entire site is unreadable. Because of the way the view code's and CSS overrides are interspersed between controllers and views, due to the fact that the original developers are complete idiots, it would take so much redevelopment to fix it that it's more sensible to just replace the whole site.
    <space for hire>
  • DodgeDodge Frets: 1585
    If you're using Chrome for Android, you can force enable zoom in the Accessibility settings.  I'm sure you can do the same in other browsers.
    Wanted:  Bad Cat Mini Cat II & other early Bad Cat amps
