Hi folks.
Looking for sone advice on which reactive loads to use with my amps for home studio use
i have various valve heads and combos ranging from marshall 18watt through to 50 watt plexi, dumble and trainwreck clones
i like to track into a neve pre and into Logic X atm.
Ideally I want to be able to run a 50 watt head with cab IRs ( or apply them in space designer in Logic ).
I dont need lots of fancy dan options - just a good reliable unit that will preserve as much of the amps character as possibe - realising that it wont be identical of course without the speaker interaction
Any recommendations - preferably second hand market.
Cheers
peteC
Nice suite of software to mess about with for IRs though, Torpedo remote for your phone, and wall of sound as a plugin.
Options for getting a DI at the same time as well, or stereo mics.
Should be fine for low wattage amps, but don't expect to be cranking stuff with the attenuation available.
IMHO reactive load works best with clean and higher gain (think JCM800 upwards) amplifier.
If you want a classic rock (Plexi) or, especially, an AC30/Matchless style on the edge of breakup then it gets harder to come across via IR's.
I use my Suhr PT15IR direct all the time and it sounds amazing.
I've never found a reactive load that works with any of the Matchless amps (and Matchless don't recommend using them).
mo. The Suhr15 sounds like a great solution but I would have to sell most of my amps to buy that so thats not an option for now.
