I play in an indie/shoegaze band and currently use a Vox AC15C1 and a large pedalboard - both great sounding but heavy and cumbersome. While the Vox sounds excellent, I rely heavily on delay, reverb, and some distortion, so I don't really 'hear' what it truly sounds like and I'm not sure I actually need a valve amp. Despite having a lot of pedals, I really only use three. At home, I use a much smaller amp as the AC is so LOUD.
I'm considering selling everything and switching to a Boss Katana 50 with a pedal controller, setting up my effects chains via the software. I assume I could set up and save effects chains on a per song basis, which would be very handy for playing live. I’d likely pocket around £1,000 and massively reduce the weight and space I’m hauling around.
Does this seem like a sensible move? Any advice or things I should consider?
LOL 0
Wow! 0
The Katana will not sound half as good, you and your band will regret it.
I don't have an alternative for you aside from recommendating a digital multieffects or BOSS MS-3 to reduce your board size.
I now either put a mfx unit straight through the PA or through my Headrush FRFR108 powered speaker mounted on a tripod stand. I can walk in and out of a gig with the 108 in its tote bag and tripod in one hand, guitar case in the other and mfx in a gig bag over my shoulder. The 108 weighs 19lbs which is half of even my lightest gigging amp. I have several different mfx and this means I have flexibility and am not tied to a particular amp.
The AC15 is a good amp and as its always good to have options, I would therefore be very reluctant to sell it as you might need it for another band. Regardless of whether you sell it or not, personally I absolutely would not buy a Katana because to me they are tinny and artificial sounding compared to an AC15 and I think you'd regret it.
Id suggest picking up a secondhand FRFR powered speaker and a second hand mfx unit. You really dont need to spend a fortune to have a good versatile and easy to use pub/small clubs gigging set up that's easy to carry and quick to set up and take down. A used Pod Go or Valeton GP200 can be found quite cheaply, ditto a Headrush 108 or similar.
There are other approaches and solutions of course, with each having pros and cons, but the above works for me.
While the Gen3 is a lot better than the previous ones I now only use it as a powered speaker for my Tonex.
i doubt it would get anywhere near the volume of the AC15.
If you want lots of effects etc then I’d go with a modelling setup. There’s a Helix LT in the classifieds for £450, and get a good powered cab to go with it.
I appreciate you wanting to cut the weight etc, but the AC15 is a fabulous amp and the Katana is just ok.
https://kottracker.com/
I used to use mine as a back up to my Code 50 for gigs, but never actually had to resort to it, and in hindsight I would have preferred to use it in the first place, just that I had my tones already set up in the Code and didn't need a lot of patches.
One time, the Code had a digital fart mid gig, and I switched over to a basic tone on the Katana to finish the gig, but the problem never happened again, so the Katana was mainly used as a stand for the Code.
At home, I have a Katana 100 head set up with the footswitch, which gives me 8 channels, plus access to effects, so that is more than enough and I haven't really dug into the tone studio on PC, there is a lot to play with.
The head is a good option too, maybe as a back up which could use the AC15 as a cab if something went wrong - but that isn't really solving your problem, maybe a lighweight cab and some sort of small back up solution would work as well.
I have no issues with the sounds on the Katana, it does everything well.
- I didn’t like the built-in effects.
- Changing presets was frustrating on the 50.
At home I have a 1980 Siverface Vibro-Champ coupled to a small pedal board containing the essential Boss TU3 Tuner, a mini TC Compressor, an Ibanez TS mini and a Strymon Flint . . . . I absolutely love the tone of my "home setup" and I only have the Vibro Champ on " 3 " or a fraction over, its just divine and I can't get anywhere near that tone and warmth with my Katana . . .
Feedback : https://www.thefretboard.co.uk/discussion/58125/
I used it on Sunday with a pretty loud band. I got a nice basic amp sound and used a combination of the built in effects with some from my HX Stomp into the front. I know I can set this up better but didn’t really have the time beforehand. It sounded good though, I have to say. Better than I thought.
Don’t sell the AC15 to buy a Katana. By all means, buy a Katana, try it out both at home and with the band, and if you like it *then* consider selling the AC15 if it’s surplus to requirements - but not the other way round.
If you want a smaller and lighter Vox amp - and assuming it would be loud enough - then I actually prefer the AC10C1 to the AC15.
Katanas are great till you want to change something you've preset on the fly - then in a live situation, forget it - you need to be using a computer and the Katana software to do very much at all.
I’ve owned both an AC15C1 and AC10C1, and both sounded much nicer than any Katana I’ve tried.
You mention that the AC15C1 is loud at home, but I recall the master volume being useable (albeit not perfect)?
Also if you only use 3 pedals could you downsize your large pedalboard to just have the ones you use?
The katana is one of the worst amps I’ve ever played through. I just literally don’t get why people buy them. I’ve been paid numerous times to connect the bloody things to a PC to access the extended EQ and try and get them to sound better but to me they always sound terrible in terms of their basic native sound with no effects compared to something like a fender champion 110 or PV bandit.
Some other people don’t hear it though, so it’s a personal thing - although it does baffle me that they don’t, since I find it so glaringly obvious.
I also found the same problem but even worse, with the Orange Micro Terror - and the Blackstar ID Core, although that was muddy as well (yes, and grating at the same time - hard to fathom how!). These three are probably my top candidates for the worst-sounding amps I’ve played.
