LOL 0
Wow! 0
With mine the trick was to use almost no gain at all on the pedal, and keep the volume close to unity. Any more was overwhelming and sounded a mess.
I've used a TC Dark Matter, MojoMojo and a Caline Orange Burst (??) before. The Caline was surprisingly good but needed the lightest touch on the gain.
You will also feedback like a bastard if you're not careful.
Was also gonna suggest a Boss OD3.
I have some sense that plugging an acoustic into an overdrive pedal might be problematic (feedback,etc) and this would be an all in one solution to those problems.
Although not the same thing I have memories of watching someone plug a strat into an overdrive pedal into an acoustic amp and creating possibly the most unpleasant guitar sound I have ever heard (this was a folk band playing Christmas carols). So this feels like an area where a few more knobs might help.
Or, if there's an electric amp at the open mic, just plug the humbucker into that and run the acoustic pickup through the PA.
Trading feedback here
Even the more 'acoustic' soundhole pickups (eg Fishman Rare Earth) sound OK with overdrive.
If you're going into an acoustic amp or a PA you absolutely need an amp/speaker simulator of some sort, or it will sound horrific. (And is a risk to the tweeters in the cabinets, at any real volume.) At an open mic this will be even more of a problem if the soundman isn't expecting or equipped to deal with an overdriven sound.
Given all that, I'd get a Boss GT-1 or a similar multi-FX - it's tiny (it will literally fit in a gig bag pocket), runs on batteries, has a wide variety of distortion, amp simulation, and every other effect you can think of, plus a basic looper.
I don't know too much about it but it can remove some of the piezo-sound, if you want, when engaged and it also has a blend.
Scout around the demos to see if this might work for you and it's relatively inexpensive
https://uk.fender.com/products/smolder-acoustic-overdrive
