Help with 80s Les Paul case handle repair
The old handle was cracked so managed to pick up a NOS handle. I sawed through the rivets to get the handle off. All the suitcase videos I watched said you just hammer the new rivet in & it will hold. These ones are loose & not sure how to fix them.
I went to local key cutter/shoe repair - he suggested I use screw & bolt. I'd rather keep it vintage correct if possible. Without the appropriate tools, am I better off seeking professional help? If so, any ideas where I could get it repaired in London? Google is not helpful for luggage repairs.
  • SteveRobinsonSteveRobinson Frets: 8953
    Something like this maybe?
  • RevolutionsRevolutions Frets: 3887
    edited August 2025
    Oh yeah, that looks pretty useful, thanks! I see the image is from Amazon - luggage screws! I'll see if I can match the size. 33mm is the shortest length which is a bit long but will be fine. Just need to make sure they fit through the holes.
  • ICBMICBM Frets: 81583
    You should able to peen the end of the new rivet over by repeatedly tapping quite gently on the edges of it with a small hammer - use a larger hammer as a stop weight at the head end. If the hole in the bracket is too large to make that easy, find a small washer which just fits over the rivet and put that on first.
  • FunkfingersFunkfingers Frets: 16090
    Once again, Steve and John demonstrate that old blokes rule. :)
    My dad died recently - he was 87 - and it’s the little things like that he taught me as a child which I will remember him best for. He was a very practical man - sadly there seem to be fewer of his kind today. I feel we (now) old blokes ourselves have a duty to pass on as many of these sorts of tricks and fixes as we can - none of it’s rocket science, but sometimes it’s not quite immediately obvious.
  • Thanks @ICBM & @SteveRobinson - few things to explore here :)
    I totally agree. One thing my Dad taught me that has served me well is that if you need to cut a bolt shorter, wind a nut down past the cut line so when you remove it it'll clean the thread up. So simple and useful but I bet plenty of people wish they had known it 'at the time' so to speak.
    It also enables you to hold the nut in a bench vice, without damaging the bolt - that’s useful if the bit you’re cutting off is too short to hold firmly in the vice. You can do the same if you’re manually cleaning up the end with a file - you can clamp the nut firmly, but still easily rotate the bolt.
