LOL 0
Wow! 0
But I'm aware I do like my gear much brighter than most people seem to
In my opinion the Blues Junior is too muddy-sounding anyway, so I wouldn’t want to remove it. But everyone has different tastes… I dislike ‘smooth’ midrange, and my idea of sparkle may be your idea of shrill.
I have a Secret Preamp pedal last in the chain, and use the bright setting for low volume vs the mid setting for higher volume.
Trading feedback here
I especially like it on these amps because it makes cleaner sounds brighter, which is what you usually want. As you turn up the preamp volume the overdrive adds more high harmonics anyway.
It’s on the input gain.. at low volumes and lower gains JMPs can be a little too bright. As you up the input gain, the effect of the cap reduces. Same with volume..get it loud and a JMP has a classic roar.
Making it switchable, gives me max range of useful tones for single coils and humbuckers at different volumes and it’s particularly practical to reduce the edge if using my JMP with some pedals for cover band stuff. Better than just clipping it is to have a couple of values you test using croc clips before soldering.
The truth is some people like there amps really dull and also some people can't hear above 10k Hz
I'm lucky if I can get it much above 1 on the master! Still sounds incredible, though. I tend to keep the presence and treble pretty low.
The problem is when the bright cap is too large, like on Marshall 1987/1959s - it lets a lot of the mid through as well as the treble, so it does sound more like ‘less bass’.
Not exactly - the tone control on the guitar is the treble bleed, not the one in the amp which is a treble pass - but it will have a generally similar result. I prefer having both options.
Orange did use that idea, using a 6-way switch, but with a coupling cap value so it acts as a bass attenuator - the FAC knob on 70s ones. These amps are hugely bassy with it set to ‘off’, most guitarists wouldn’t normally want that much.
I put a variable NFB in a champ build along with some cathode bypass gain boosts on switches.. sounds epic through a celestion cream Alnico.
