In any case just because the chords on The OP's example are not diatonic, doesn't mean the progression can't be explained/put into context by theory, it *has* above :-)
So they went for the double switch-a-too
There might be another way to analyse this but to me the tonality is established clearly by the two opening melody notes, a major third followed by the root
Interesting that it's a 60s pastiche @Blueingreen given your comment earlier. Well observed
CMaj is C-E-G
Amin is A-C-E Relative minor
Emin is E-G-B secondary relative minor
I've been watching a lot of piano videos recently and they call them "borrowed chords", usually from the parallel major or minor key. A *very* common example in pop and rock is using the major key root chord with the minor key seventh degree chord (e.g. C major to Bb major).
Well, they did switch-a-two (II) and then switch-a-four (IV) so maybe the auto correct is almost there, and possibly cleverer than we think?
