menamestom
Frets: 5459
LOL 0
Wow! 0
Firstly whats the action? if its too high it will throw out the intonation. About 3.5-4mil at 12th fret 6th string is about as high as you'd want it.
The thickness of a trad nylon G string also exacerbates this issue, try a set of 'carbon' strings, they have much nicer thinner G strings. CG players often buy packs of carbon Gs to change out the G in whatever set they like. D'Addario Composites also have a thin non-trad G string but its brown and pretty hard. Some people like them.
Having a compensated saddle cut for the bridge will help sort this problem also, but obviously depends on what you want to spend...
The action seems reasonable for a classical, probably 4mm so could perhaps go lower. There is ample bridge and a decent break angle to play with so that is something I might try. Perhaps just start with a slight action lowering and new strings.
Possibly try a carbon G. Guitar is a spruce top (Cordoba C10), sounds really nice, my only thought with carbon is it's probably the opposite direction I'd want the tone to go in as the guitar is already clear and strident. But in all honesty being in tune is more important that string nuance.
I don’t have the old one to compare as it lives in Spain now.
Great, will give one a go, may as well experiment a bit.
This may be the final solution - I’ll not lose sleep over it but if I could improve the G string by 40% that would be good enough.
It usually is possible to carefully sand some G string compensation into a bone or synthetic bone classical saddle yourself using a fine flat needle file or fine grit sandpaper wrapped around a narrow flat piece of wood, but you have to be careful with bone as it is brittle and breaks quite easily. If you need help finding a pre-compensated saddle that will fit, let us know the dimensions of the existing saddle.
I've had a watch of that video now and it's all starting to make sense. My bridge is 80x3mm so both of the ones you posted should fit. I'll probably have a go amending it myself, if it breaks it will be easy enough to get a replacement.
First of all I might try a thinner G string and see how that affects it. I'll probably have a few string experiments first and see how the set I settle intonate then go from there.
I'm tempted to try some D'addario EJ46LP. The guitar currently has the ones Cordoba reccomend according to the previous owner which are Savarez Cristal Corum High Tension 500CJ. I like the idea of the EJ46LP as they reduce finger noise (I'm going to be doing a bit of recording), are slightly mellower and also have a composite G string.
But first I'm just going to try a carbon with the current set.
Then when I've decided on strings I'll see what the bridge needs. Thanks for all the info, this won't niggle now I know it can be rectified or at least improved quite a bit by compensation and / or string choice.
