stickyfiddle
Frets: 33140
LOL 0
Wow! 0
I have one of these… the dividers make cable management much much better.
You may want to get a roll around tool box though for your situation for power cables and all the random stuff.
https://www.amazon.co.uk/STANLEY-STST1-80151-Essential-Rolling-Workshop/dp/B06XCBPFRN/ref=asc_df_B06XCBPFRN?mcid=13dd693b5eab3701a2be335014f1cc60&th=1&psc=1&tag=googshopuk-21&linkCode=df0&hvadid=697251922476&hvpos=&hvnetw=g&hvrand=4098835705731458935&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9191165&hvtargid=pla-303798481808&psc=1&hvocijid=4098835705731458935-B06XCBPFRN-&hvexpln=0&gad_source=1
I put small stuff in clip top food containers to keep them organised… fuses and repair stuff, strings, plectra, tuners and capo, etc.
I also have a dedicated mic bag.. holds 6 vox mics and amp mics and a couple of SDCs as well as the iPads for controlling the mix.
@Moltisanti that would be lovely except way less useful because my car isn't on the ground floor so I'm taking lifts & double doors either way...
Or you could get the singers to bring anything that isn't guitar-related.
For events where PA and lights are provided the trolley takes guitar, toolbox, pedalboard, amp and speaker all in one go.
Pitfalls: the trolley can handle single steps, but not staircases. It also wears. I’ve fitted stronger 10cm wheels than came supplied. Plastic cases can crack. Ours were bought years ago, and are substantially stronger than modern ones. Doors used to be a problem, but I now carry wooden wedges
Good quality too
https://www.thomann.co.uk/thomann_doppel_gigbag_egitarre.htm
In other bands everybody brings a bit of gear, one guys brings a bin and a desk, another guy brings 2 tops, another guy brings a bin and all the required cables.
A lot of the time I'm just bring an amp, a pedal board and a guitar, with my little foldable sacktruck I can wheel that with one hand while drinking a beer if I want to
Guitars - hard cases
Amp - amp cover
Pedalboard - Mooer pedalboard wheelie case
I can manage the above in two trips
flanging_fed “
This is the bands gear that doesn't travel home with the members
It looks bad but because almost none of it is a one man lift, no one really carries anything heavy.
We'll be requiring venues to provide PA for the stuff we're doing so that cuts it in half. So far we just have to worry about instruments, amps and IEM rig
The idea is everyone plugs into the splitter rack . The splitter has 2 outputs per channel. One set of outputs goes to your digital desk ... those ones never get moved. The other set goes to a loom which is left in the back of the rack. You get to the gig, pull the loom out the back and give that to the engineer along with a channel sheet. He plugs that loom into his stage box and doesn't get involved in your IEM mixes. Those are set and saved by you buy each band member can tweak with their mix with phone / iPad etc.
This system allowed us to be up and running with great IEM mixes within an hour of load in ... and it wasn't that expensive .. I bought two 8 channel splitters from studio spares for £200, and a used UI24 on here for £450. the rack was £38 and the loom £25 I think .. in all.
Of course you can use it for FOH mixing as well via an iPad. We got to the one well known Liverpool venue and they had a bad leak. The FOH position was waterlogged and their X32 was covered in water. The engineer wanted to cancel. Fuck that, we had hotels booked, show was sold out and we were on great money if it went ahead. So we plumbed in as normal and I gave him my iPad and he mixed the show from the back of the room. Had I not had that splitter rack it would have been game over.
https://www.gear4music.com/Recording-and-Computers/Trojan-Pro-Cable-Gig-Bag-40/6TA6
