Brio
Frets: 3587
LOL 0
Wow! 0
I can see GU66 UK have a UK price of £789 and they arrive in December and they're 'Sold Out', so presumably, there's a waiting list, as was the case for the VP4.
https://forum.fractalaudio.com/threads/4-blocks-are-not-enough-see-this.216967/#post-2729466
Looks great, I was eying up the VP4, but this could serve the role of live backup amp ,in addition to effects on my board and home recording modeller, rather than the effects only of the VP4. And you can still use 4 blocks for effects if you need to.
The lack of pitch would mean I’d have to keep my HX One, which means I probably have power headroom issues, so it’s not a no brainer. Also, neither of them have a looper which is another thing I use my HX One for. Whilst they would pair well together, £1400 and still no basic looper is a bit of a pain.
But still seems good value, compared to say a Big Sky MX or H90 and the effects are probably better than their line 6 equivalents. Many people complaining online a HX Stomp has more blocks but for people like myself who just want 4 effect slots at their feet and a backup amp on their board, it is ideal. And I think most people think the Fractal effects and modelling is generally better than Line 6. I really like my HX One, but none of the effects particularly blow me away.
My initial thought is that if you are getting the VP4 and the AM4 then you are getting close to the price of the FM9 but my issue with using the FM9 is it is so damn wide- put a couple of expression pedals on the end and you are taking up half the stages that I play.
So an AM4 + VP4 in an XDM Schmidt Array case and you are getting a lot of capability.
I'd need a couple of external pedals- certainly my Hexe Revolver IV because nothing else does what that does, and maybe a couple of analogue drives, but this is a very compact set up.
I probably won't go for it though because of an issue, which is how do I monitor the guitar signal?
With the AM4/VP4 or the Kemper, Axe FX III, FM9, Tonex (which I already have) I either have to use an FRFR, a tube power amp or some sort of tube power amp.
I've spent a lot of time figuring out the optimal way for me to gig monitoring typically through a guitar speaker but with a direct out option and the best I've found is to use the Suhr PT15IR head in 4 cable method. I get a direct out and can run it without a cab for silent or near silent stages, or I can plug it into a cabinet if the backline supplies one or use the 1x12 greenback loaded Zilla cab that I always have with me.
In terms of a backup amp on my board, the Tonex One is the best option I've found because it is so compact, but the Kemper Player would possibly be an option too.
I'd love fractal to do a compact £200-300 amp sim only box that allows you to switch between a single amp/cab block using the 4 channels we currently get with the larger devices.
https://www.theoddfoxes.com/
Pure amp
+ Boost
+ Saturation
+ EQ
(Even more if I think about the cab (Vs separate IR block), the room setting and the output compression. That'd be all eight blocks on my Stomp...)
And that's all in one channel of the same block - I'll have four channels on the AM4. It's actually quite impressive but obviously four blocks sounds like less functionality than eight blocks.
This may make sense for me as I'm not a massive FX user. 1 thing I'd wished they'd done though is have a standard 'Modulation' block rather than individual, Chorus/Phaser/Flanger blocks.
I know they have 4 channels to each block, but 4 channels of Chorus (for example) is useless to me whereas a channel of Chorus, 1 for Phase, 1 for Flange and 1 for Univibe would've been far more useful to me.
In an FM3 I could have a block for each, but with the 3 block limit on the AM4 it makes it more complicated imo.
Trading feedback here
There was a great explanation earlier of how the '4 block thing' is not much of a thing at all (thanks for sharing the link to the forum!), and as long as you're not expecting this to be an FM3 or FM9 at this price point, I don't think you're going to feel restricted.
The FM3 and FM9 will ALWAYS be more powerful - hence the price, but this is full fat Fractal quality for the masses; a great entry point into the Fractal world and a great backup unit for those already in it (like me!). Some interesting videos on the way over the next few weeks from a few great folks - watch this space...
http://www.g66.eu/ http://www.zenrigs.com/
And I could be seriously tempted to try one.
I really need to spend time with one but being honest I am more likely considering a VP4 to go with my Nano Cortex and then selling my Kemper Player, waiting to see how the Mk2 profiling works.
