Penn
Frets: 1637
LOL 0
Wow! 0
I think I have the slightly older CD version of the one you linked, and I probably only really used it a couple of times.
If I recall, it also had a hard drive, and the CD was used to bounce out final recordings, the newer versions use an SD card for memory and storage, and they still came with fairly large paper manuals.
My most recent one, is the Tascam model 12, which also came with a huge manual, and is a couple of steps above the one you linked, cost around £500, but is a very versatile machine.
The more modern stuff usually also work as IO for a PC, giving multiple inputs for a DAW, and aslo can work as a control surface, because once you make the leap into DAW land, stand alone recorders become less attractive.
Zoom also make a few similar devices, and the R16, for around £200 was an amazing piece of kit-even worked off AA batteries for truly mobile recording.
The workflow will be a bit different, depending on what you want to do, either record and mix on the machine (limited, and probably closer to old 4 track ways ) or simply record and export into a DAW ( or record through straight into a DAW )
Really depends what direction / how seriously you want to get with it.
A lot of stuff around the same price points now, but you can't really go wrong with either Tascam or Zoom.
Thanks for the response. I really don’t understand all the DAW and stuff like that.
https://www.andertons.co.uk/zoom-r12-recorder-interface-controller-sampler/
It’s blowing my mind how cheap these are. I feel like there must be a catch.
Fine, if you spend a lot of time with it, but for anything more than basic recording there is a lot of menu diving to do.
Really, any recording you do has to be the best possible quality you can achieve, and be somewhat future proof.
Imagine you put your phone on record, and play a perfect take into the mic.
Now imagine you want to overdub that recording-how would you do that?
In my world, I would have to export the file into a DAW, which then I could build on.
With these type of recorders, they take it a step further-you record onto one track, and then you can use track 2 to overdub, and so on--just like an old 4 track tape.
Obviously, when you have recorded onto every track, things can be mixed for level, panned and eq'd to a basic level, then you usually can 'bounce' it all down to a stereo 'master mix', and then you are probably left with an MP3 file to listen to.
These modern mixers usually have a basic drum machine built in as well, so you will soon have to learn how to build up a backing track from loops to create a 'song'.
These things take time to understand, which often ruins any creative 'flow' you have going, so things can be slow progress.
All this effort needs to be future proof, so that in the future, when you have some good ideas and 'songs' built up, they can be taken from the common SD card storage, preferably in WAV format, and imported into a DAW where much mor complex editing and refinement can take place.
My DAW of choice is Reaper, it costs nothing to try, and there are tutorials available from a very basic stage which answer any questions you might have, really is amazing software.
See if you can find one of these, shouldn't be hard,
https://www.boss.info/uk/products/micro_br_br-80/
For simple recording, it is an excellent bit of kit, and the process of using it will be similar to everything I describe above.
A good way to dip your toe in, before you decide how deep you want to get.
https://adamharkus.com/should-i-buy-a-boss-micro-br-80-digital-recorder/
Any editing is usually best left to something with a big screen and mouse. I had a Tascam 32 and it sounded amazing and if used in a simple way was easy to capture ideas, but it tempted more editing with all the features and then it got too complicated.
There's lots of menu diving stuff for mixdown/editing/mastering, but I don't use all that ... just record ideas, then transfer to Logic if there's something really good (occasionally there is
They're old tech now (especially the screen), but if you can get one for a good price I'd recommend it.
