LOL 0
Wow! 0
I'm guessing the bias voltage for the red plating pair is less negative than the other side, possibly a leaky coupling cap, but you'll need to take measurements to confirm.
You might also try swapping each pair side to side to see if the problem follows the valves or stays with the sockets. Unlikely, but best not to assume.
BTW the output valves are V4-V7.
Rift Amplification
Brackley, Northamptonshire
www.riftamps.co.uk
Thanks a lot Chris, I will start exactly with those suggestions.
If it stays on the same side, swap the inner pair and repeat. If the fault stays on the same side after both swaps, it's a fault with the amp not the valves, and as RiftAmps said a coupling cap leak is the most likely. If the fault moved with a valve, you know which is the faulty one - although the other one from the same side may also be damaged if it's been running like that for a while.
Will report back when I get a chance to check.
Cheers
I swapped the outer valves as discussed and now there is no red plating at all!!
All working normally now.
i played a loop through it for a few hours and all sounded normal.
Any ideas why that have fixed it ?
Could a dirty/bad contact on one of the tubes have caused the red plating ?
Thanks again for the great suggestion
I did another test just by putting a looper through the amp. All still sounded fine.
Then I did a heat check with a temperature gun on the power valves , only to discover V4 is completely cold. Hadn’t noticed previously as the room is quite bright.
That is one of the previously red plating valves that i moved from V7.
So I will need to now go deeper and open the amp
up and check voltages on the sockets etc.
The valve was obviously functional
before I moved it as it was red plating.
hopefully it is just the valve that is the issue.
Will update during the weekend probably.
Thanks again for all the help so far.
Both tests successful and amp sounds fine now.
Thanks again to all for the great suggestions.
The bad news is that valves can do this sort of thing, and it isn’t uncommon.
The good news is that the problems are usually relatively easy to troubleshoot and fix.
Although rarer, if this happens to a power transistor in a solid-state amp, it’s more likely to damage other parts, and will be a bench job to repair.
So now that the amp is working well on two valves I decided to remove the chassis to clean some noisy pots. While I was in there I happened to test the continuity on the triode/pentode switch and then on the 8ohm/16ohm impedance switch.
Pentode/triode switch appears completely normal but when i test the continuity on the (top and bottom) three legs of the impedance switch, they are all connected whichever position the switch is in !!
Is there any reason(other than a faulty switch) that this could happen ?
I suspect I will have to remove the switch and test it out of circuit.
indeed it works in both positions.
i was just concerned I might be damaging something.
That’s great information again.
Very many thanks.
Many thanks for the suggestion
