LOL 0
Wow! 0
The Takamine GN93 came with a TK-40D preamp.
Takamine preamps - following quotes from that page:
Takamine preamps use two different types of plugs for input and output - so an incorrect connection cannot be made. So having one jack and one phono is correct, presumably for all Takamine guitars.
The TK-40 and TP-4T preamps are both designed for use only in G Series model guitars and are not compatible with Pro Series Takamine guitars made in Japan. My Takamine ('97 Ltd edition) uses a different preamp and is not campatible with yours, so looking at mine may not be as accurate as we need. I have one jack and one phono, both plugged into the preamp.
Here is what I see in my Takamine:
I am confused by your two braided wires.
For the battery cover, see here for someone selling them via ebay, or here for a shop selling them, both US based.
Is that a valve in yours?
Yes, when my original preamp died (which I now understand is the sign that the capacitors have had it) I bought a Cool Tube preamp. It sounds fantastic, especially when played through my Fender valve combo. Sorry, I shouldn't make you jealous; enjoy your GN93.
If you remember, add a note here when you are happy that your Takamine is working as it should be. It would be nice to know when you have it all sorted.
What happens with all the Takamine preamps (and maybe all preamps) is that the capacitors inside stop working after a number of years. Rather than risk an old TK-40D where you have no idea how long it will be before that packs up, a brand new TP-4TD is probably going to give you the most years of reliable service.
Thomann, for example, stocks them - here - but buy one from your nearest and favourite shop.
I hadn't even thought about a new one but the price of the used TK 40's was scaring me a bit, especially as you say, they may not last very long.
I intend to give this guitar as a gift to my daughter in law so will feel much more confident with a new pre amp.
