(This might be a bit of a ramble, but I'll try to highlight any actual questions when they occur.)
I have an old ('99) Gordon-Smith Graduate, which I've owned since new but never quite loved, so I thought I'd give it a bit of an overhaul, and incidentally branch out into working on LP-type guitars - I've done several complete re-wires recently as part of an ongoing effort to work on my soldering skills, but they've all been on Strat types.
The plan is to completely rewire the guitar as the pots are a bit scratchy and the current pickups aren't great. I have the replacement pickups lined up (a pair of Oil City Nightfighters), so I thought I'd do a bit of prep by watching a couple of YouTube videos, reading the appropriate sections in Gerry Hayes's "Complete Guitar Wiring", and opening the control cavity on the Graduate to inspect the current layout.... which is where things started going askew.
First off, I reckon this particular guitar is a Friday afternoon special.
I picked it up relatively cheap back in the day on account of some flaws in the finish, but when upgrading the tuners (relatively recently!) I noticed that they're placed somewhat lopsided, and having inspected the control cavity, the routing is rougher than a badger's bum-bum. I reckon this guitar's going to be an absolute pig to work on when I get into it.
Secondly, the wiring layout is awful - a proper rat's nest. All of the reference materials I've looked at so far follow a recognisable pattern: four pots with capacitors linking the volume and tone controls for each pickups, with a ground wire going to the bridge, and a bare ground line connecting the pots. The GS follows none of this - there's no visible ground wire to the hardware or connecting the pots, and the capacitors are not used to link the pots. I suspect I'll just have to spend a bit more time looking at the layout to work out what's going on, but I guess question one is: is there a reason why reference materials seem to favour that original layout with capacitors strung across pairs of pots?
(Side note: I have a pair of Korean Epiphone LPs of similar vintage and opened them up to see if I could glean any insights from their wiring, since they both have coil splits. The wiring on those is also terrible, and no two of these guitars has the same wiring layout. ::sigh::)
Question two would be: does nobody bother screening the control cavities in LPs because the position of the switch enforces the use of screened wiring, which makes all that fiddly business with copper tape redundant?
And, on the subject of screened wiring, is there a good reason to choose one type over another? Is braided easier to work with than screened PVC, or vice versa?
Lastly: how far into this do you think I'll get before I say "Sod it, I'm going to turn this over to a professional"?
If you use shielded cable throughout, and the caps are on the tone pots so the volume and tones are linked with cables, there is no need to connect any of the pot casings other than with the cable shielding, and no real need to do any other shielding - although it can make a small difference if the exposed wiring cores aren’t kept as short as possible.
Be aware that the pickup cavities may need enlarging as they will be cut just the right size for the proprietary pickups.
This is also true of PRS. I once considered installing covered humbuckers in my early Nineties Custom (24). They would not fit. The corners of the pickup cavities were too rounded.
I can't decide whether to be outraged on their behalf or simply nod and say "Fair".
1) I just get the vibe that this guitar is going to be troublesome.
2) It's a Graduate 60 - single cut, selector switch positioned per a proper LP.
3) Current wiring run from the switch appears to be one single-core screened wire direct to the jack, and one multicore?
4) The Nightfighters have four-conductor wiring to accommodate splitting.
5) Wiring channel is approx. 7-8mm in diameter and comes out in the control cavity very close to the bridge volume pot.
I suspect I might end up attempting to rewire one of my Epiphones first - changing the pickups was on my to-do-list anyway, so maybe it would make sense to use it as a practice run before taking a tilt at the GS.
I did indeed use one of my Epiphones as a dry run. I did most of the work back in March, but finally got round to fixing the last ongoing problem as part of my Bank Holiday guitar work programme... and have even got around to putting some pictures on Flickr.
The new harness was mostly okay but developed a fault where the neck volume control had no effect - the pickup still worked, the coil split on the volume pot worked, but the pickup was just always on full. Hence I've been back in today to clean up. I'm not sure what the fault was but I've removed the treble-bleed assembly from the neck volume (which was an unnecessary complication anyway), resoldered the pickup & switch connections, and all is good.
