paulnb57
Frets: 3949
LOL 1
Wow! 0
When the MC5 were around, that was during the time of Vietnam, Nixon and the Kent State University shootings, events not dissimilar to what's happening today. And he used that guitar to play songs critical of the US like American Ruse.
The only downside of painting it the original colours is that you might have to explain who Wayne Kramer was to anyone suspicious of your intent.
Router bearings turned up today so it got routed for the humbucker
Note the HiTec workbench!
And mocked up
Actually the “routing table” was surprisingly stable, there was an old towel folded under the body didnt didnt move around, Im not the most confident routererer, but I didnt feel any concerns while routererering…
In other news I cocked it up, despite measuring several times Ive got the middle pickup off the centre line by about 5mm, now I managed I dont know! Easy enough fix but the scratchplate is scrap….pickups are with the exception of the neck are all wrong
The bridge should have been a BK Sinner, but the leads were too short, so I replaced them and broke the ground winding, couldnt unwind a turn as its trapped under all the rest of the winding, so thats f*cked……theres an SC size Iron Gear HB there, but really it should be an SC. Middle is a hot ceramic jobby, far too powerful
I think I will not paint the body
However it has confirmed it is worth carrying on with….and easily reversed when (if) I ever find a real Fender jobby
Then, when out with the dog (great thinking time!) I realised I could have used the existing roit and popped a SC size humbucker in the middle position and created a 21st century interpretation…not quite so good visually, but as darn sight easier! Bit wheres the fun in that?
Onwards!
You can sometimes fix a broken pickup wire at the eyelet if there’s enough wire sticking out of the coil to very carefully scrape some of the coating off and solder a fine piece of wire to it - a piece of the shielding from a guitar cable is often good - then solder that to the eyelet. Not pretty, but it works! I usually cover it with some melted wax to stop it getting disturbed once I’m sure the pickup is working.
