Up for grabs!
Firstly, The WHITE LOOP is a two loop true bypass looper. What separates the WHITE LOOP from many other similar products is the flash loop function. The WHITE LOOP has a green and red loop. One switch toggles between these two loops. The second switch bypasses both loops.
The WHITE LOOP also has two DC outputs and can also be used as an amp channel switcher white you aren't using a loop.
Basically stick a pedal in each loop and you now have the ability to switch between the two plus your bypassed tone. Or stick a couple of pedals in a loop for a preset sound. Can even be used to switch channels on certain amps. Loads of options!
Looking for £50 PPG inc Postage.
Secondly,
As above, excellent, probably mint condition.
Gigged twice, plenty of home use.
Original box, psu etc
3M Dual Lock on the bottom, more secure than Velcro.
Just a bit ott for what I need now, slowly simplifying my rig.
£325 OVNO shipped RM SD PPG only.
